Dual Orion XS 50 DC-DC chargers in parallel only yields 46a
I have wired two of these puppies in parallel and using a 1/0AWG cable from the truck. In the travel trailer the 1/0 is hooked on to a 250a buss bar. Then the two Orions are connected to the buss bar with 4AWG cable. However, I can only get about 46a combined output from the two. Roughly in the 26+20 ratio. The one yielding higher amps varies. Attached is the picture.
I have successfully used them to yield a total of 90a when connected to different batteries with two parallel 4awg runs and part of a different system but connected to the same alternators. Currently, they are part of the same ve network, same venus device and hence same DVCC whose charging current is limited to 200a. The vehicle has dual alternators rated at 257a and 197a.
What are the software settings and hardware connections I should be checking? Note, both Orions are seeing 13.5 input voltage.
Batteries accept 120a with the Multiplus II charger and that’s just 0.1C. It’s not the batteries.
Thanks for the reply. I appreciate it.
You were right. Removing them from the network fixed the issue.
So, they can’t be part of the network? Or, did I set them up wrong?
Could someone kindly provide a little more detail, as to what the problem & solution here was, to increase the charging amperage?
What specifically does “cut out the networking program them as individual units” mean?
Does it mean physically remove VE.Direct cables from the DC-DC chargers?
Or, is there a “running in parallel” option somewhere in Victron Connect app, which needed to be turned OFF?
I am looking to do similar, and curious what the problem was here. Thank you.
Thank you very much for clarifying the solution to OP’s issue here.
