Da bleib ich doch mal dran ![]()
Hier bei mir hƤngt auch noch ein Samsung Tab 3 unter Android 4.4
⦠Jetzt schƶpfe ich doch wieder Hoffnung ā¦
Danke
Updated to new version on Amazon fire hd8, had to install firefox to manually download new app version - built in browser wouldnāt download app( web address for app taken from QR image) and works a treatš
Then you havenāt done anything special, just started the Remote Console via the browser. ?
This article is about the complete replacement of the OS by the Victron interface ⦠In other words : the Pad is only āRemote Consoleā ⦠Nothing else
Nothing special, just using newer version of app.
And NO it isnāt just remote consoleš
Here is the debug output from crashing app on android x86 (mi pad 2). App crashes instantly with āUnfortunately gxDisplay has stoppedā message.
11-13 20:44:55.860 13830 13850 E AndroidRuntime: FATAL EXCEPTION: SocketListener(10-9-8-217.local.)
11-13 20:44:55.860 13830 13850 E AndroidRuntime: Process: com.victronEnergy.gxDisplay, PID: 13830
11-13 20:44:55.860 13830 13850 E AndroidRuntime: Theme: themes:{}
11-13 20:44:55.860 13830 13850 E AndroidRuntime: java.lang.NoClassDefFoundError: javax.jmdns.impl.DNSIncoming$MessageInputStream$$ExternalSyntheticLambda1
11-13 20:44:55.860 13830 13850 E AndroidRuntime: at javax.jmdns.impl.DNSIncoming$MessageInputStream.readName(DNSIncoming.java:152)
11-13 20:44:55.860 13830 13850 E AndroidRuntime: at javax.jmdns.impl.DNSIncoming.readAnswer(DNSIncoming.java:301)
11-13 20:44:55.860 13830 13850 E AndroidRuntime: at javax.jmdns.impl.DNSIncoming.(DNSIncoming.java:220)
11-13 20:44:55.860 13830 13850 E AndroidRuntime: at javax.jmdns.impl.SocketListener.run(SocketListener.java:66)
LineageOS 13, Android 6.0.1
has anyone tried to end the Kiosk-Mode?
I used my Samsung M33 5G to install and test and would like to use the Phone now for normal purposes again.
Hard-reset does not work�?
thanks,
Daniel
Check the manual to learn how to open the service menu, there is an option to factory reset the device.
If it does not work for you, google how to boot into recovery mode for your phone model.
ok, i needed to tap at the bottom left corner for 5 seconds, just found it.
Thank you very much.
Hardware reset with the power and volume button didnĀ“t workā¦
Thank you, weāll look into this and see how we can fix it.
Samsung Galaxy Tab A with Android 7
I use to have also crashes at the beginning, but after controling all, I discover the cause (in my case) was the connetion (Wifi, Lan and Box) after some Box reset/tuning cables check and Venux connetion control⦠3 days without crashesā¦
hi
ok on redmi pad se 8.7 ![]()
Hi all
juste tried to install the GXpanel app on my NSPanel Pro (currently used for Home Assistant app display).
As a reminder, the NS Panel Prod is a nice square touchscreen panel running android 8.1.
No problem sideloading the application (which is nice since the VRM app APK from 2.8.1 need at least Android 9) and launching it. However twoo issues with gxPanel:
- the application rotate screen by force in ālandscapeā (by 90°). Android setting are not in a position to rotate the application back to 0° (only 90 and 270° setting are effective, but both are in a way or another 90° for NSpanel regular use)
- application enforces a kind of 16/9 display, which means there is a big empty area below the dashboard
Do you think the application could be corrected to better fir with ānon tablet type of formatā ? If yes, this would be really great ! ![]()
Thanks
Matt
Is the Dropbox link kept up to date with the latest APK?
Iād like to be able to run other apps on my tablet as well as this, rather than just having it in kiosk mode with one app.
Cheers
Josh
as far as I can tell, yes it is. However, the filename does not change.
After downloading and installing the apk, you can see the version in the control menu of the app and will notice, that it has been upgraded.
Thanks! ![]()
I love the new gui on the tablet!
Great work. Only after two days I have a white screen.
All I can do is restart and then all is fine.
Kind regards
Jacco
Itās android. Itāll crash from time to time, nothing to do with it.
Am I the only one?
After 1 week all good with a Galaxy Tab 9 Android 7.1.1 (No plan to upgrade android to upper version)
Crashes could happen with connection trouble⦠perhaps some energy saver system or other make your device to switch to blank screen.
Xavier
