1. Introduction
This procedure and software will turn an Android tablet/phone into a dedicated display for GX products. The app, once installed, takes over the device, running in kiosk mode to ensure it functions as a dedicated display for GX devices. This means:
- The tablet will only serve as a GX display, restricting access to other applications and features.
- Users will not be able to use the device for general purposes like browsing or installing apps.
- The device will remain in this mode until manually reset.
This setup ensures a focused and reliable experience, allowing the Android device to act as a permanent display for monitoring and controlling GX systems.
Disclaimer: This software is in the beta stage and is not intended for end users.
2. Installation
Prerequisites
Android Device: The device must be in factory reset state.The minimum supported version is (theoretically) Android 6, but it is recommended to use a modern Android version as it has not been tested with older devices.
It is not guaranteed that the software will work on all Android devices, as compatibility depends on the hardware capabilities and the manufacturer’s implementation of Android features.
QR Code: You will need a QR code provided by Victron, see below.
Venus OS: Your GX must be running firmware version 3.50, which is currently in beta. See: https://bit.ly/venus-v3_50_beta
Prepare the Android Device
Make sure that the Android device has been fully reset to its factory settings. This means:
- The device should be restored to its original state, as it was when first powered on.
- If the device has already been used, perform a factory reset through the device settings by selecting the ‘Factory reset’ option..
Installation Steps
- Power on the device
When you power on the Android device for the first time after the reset, you will see the welcome screen. - Open the QR scanner
Quickly tap the screen six times around the “Welcome/Hello” text to start the QR code setup. This will open a QR reader.
- Scan this QR Code
- Follow the installation steps, this include.
- Connect to Wi-Fi: Internet connected network is required to download the application and install the application. Alternative Wi-Fi connections such as GX built-in access points can be configured later. Once installed, the internet connection is not required anymore.
- Some Android models ask for location and Wi-Fi scanning permissions, these permissions are optional but required for best operation connecting to Wi-Fi and finding GX products in the network.
3. Configuration and Usage
Once installed, a basic setup is required:
Wi-Fi configuration (optional)
At this stage, the tablet is already connected to the Wi-Fi network used during installation. You can either choose to connect to a different Wi-Fi network or directly connect to the GX’s built-in access point. -
Select a GX
The app will find all the GX in the network, choose the one that the tablet will serve as an external display for. -
Set a PIN code (optional)
A PIN can be set to restrict access to the configuration menu, where you can modify settings as needed.
4. Service menu (For display and other settings)
The service menu offers the possibility to change some of the already configured settings and others.
How to open the service menu
Press and hold for 5 seconds at the bottom left corner of the screen. If set, the PIN code will be requested.
This menu offers several functions:
- Display Setting: Opens the Android display adjustment options (e.g., auto brightness, screensaver duration, etc.).
- Keep screen on: Some Android devices do not allow you to configure the display settings to keep the screen always on. You can use this toggle in such cases. The tablet display can always be switched off by pressing the power button once.
- Search for Devices: Allows you to switch to a different GX on the network. This can be used when replacing a GX or to use the same tablet to monitor different installations.
- Wi-Fi Settings: Allows you to connect to another Wi-Fi network.
- Reload Web: Reloads the interface.
- Factory Reset: Allows you to quickly perform a factory reset if you want to stop using the device for this application.
