Version 1.3 of the Android GX Display app is available. It is a maintenance release that
fixes the three problems reported here after v1.2. There are no new features.
How to get it
Displays with automatic updates enabled will install it by themselves during the night.
To update straight away, open the configuration menu by pressing and holding the lower
left corner of the screen for five seconds, then use the manual update check.
Highlights
Fixed displays cycling between the GX devices of an installation that has more than
one of them.
Fixed the screen staying blank after being turned back on.
Detailed list of changes
Networking
Fixed Venus devices that publish no serial number of their own being treated as one
device. A Raspberry Pi has no serial number sticker to report, so several of them
announce the same placeholder. They are still listed during setup, but are no longer
followed around the network.
Display
Fixed the screen staying blank after being turned back on, when the browser’s graphics
process had stopped without being restarted.
Added a check on every wake for whether the page is actually showing anything and trigger a reload when necessary.
Interface
Fixed the Android navigation bar staying visible over the page, where it could cover
the lower left corner used to open the configuration menu.
Feedback
Please report any problems in this thread, and include the tablet model, its Android
version and the GX device you are using.
I am seeing a behaviour that I already noticed when updating to v1.2. Android shows that a system software update is available, but when I tap “Download and install”, nothing happens. The notification is still present, and the button remains unresponsive.
Within the Victron app, I can also see that a newer version (v1.3) is available. However, when I tap “Install”, nothing happens there either. Beta updates is “OFF”.
I have already performed a restart (long-pressing the power button), but this did not change the situation.
The improvements introduced with v1.2 are excellent. The connection process is noticeably faster now. One minor issue I have observed is that the start page occasionally switches to “Brief” instead of remaining on “Overview.” This only happens intermittently, and so far I have been unable to identify a pattern.
To update to v1.2, I performed a factory reset of the tablet and set it up again from scratch. The tablet is used exclusively as a GX display. At this point, I would not yet repeat the factory reset, as I would like to assist with any troubleshooting or debugging you may wish to perform.
Please feel free to contact me if there are any specific tests, logs, or diagnostic steps you would like me to try.
For me, it seems like the device management or something else prevents the update based on OS and/or APP level via policy. But this is a just a guess.
Try to go to Android settings (in the low-left hidden menu), go to Applications, find the GX Display application and set “admin rights” to enable (I don’t remember the exact setting, I’m not home… But it’s something like this)
I checked my Android Settings - Apps gxDisplay. But I cannot find a setting like “admin rights”. Would be great if you would check your Lenovo tablet when you are back home and post the exact setting you changed for the App.
When you say “same problem”: Are you not able to update to gxDisplay V1.3 via the “Check for Updates” and “Install” button? Or does your tablet refuse to do the latest Android Update? Or both?
Good Morning Christian. I tried that setting on my device. Reboot, retry. Effect remains. I can neither update the gxDisplay App to V1.3, nor can I activate the Android System Update (15 to 16, One UI to 8). Just nothing happens when I click the buttons. Everything else is working fine. Looks like something invisible blocks the updates.
Pretty sure, V1.3 would be installed after a factory reset, like I did it with V1.2. But I will wait for a few days. Maybe Victron wants me to debug or try something. The App itself is working without any problem and the tablet is robust and well designed. Would be great to identify and eliminate the root cause
Update 10.10.2026, 10:00, the device keeps reminding me to install the update V1.3. But when I click on Install, nothing happens
I have it on several tablets as I have several PV systems on microwave sites. They upgraded very well. The one in my van also upgraded but now it is stuck in light screen mode no matter what I set on either the tablet or the app.
The tablet is a Lenovo TB-8505FS, I do not recall the android rev level but I have it to whatever the latest it will take is.
Prior to the upgrade the screen ran in dark mode just fine.
We are recently having issues with Motorola, hopefully I can get my hands on one this week as these oversees customers say it doesn’t work at al in V1.3 Mmmm, which Is doubt, I will post asap.
Venus OS v3.70 added a separate appearance setting for the Remote Console, so it no longer follows the GX display automatically.
On the GX, go to Settings → General → Display & Appearance. Set Remote Console appearance to Same as GX display, and make sure GX display appearance is set to Dark.
With it on Auto (the default) the Remote Console follows the tablet’s own system theme instead, which is likely what you’re seeing.
It would be nice to know what “doesn’t work at all” actually means.
Anyway, we’re going to release a new version soon that should address some of the issues reported in the community. Hopefully, it will also fix the issue your customer is experiencing.
Thanks, that helps. A few questions so we can pin it down rather than guess:
When you press Install, does any brief message appear on the screen in the following minute or two — something like “Update download error!”? It only shows for a few seconds, so it’s easy to miss.
Roughly how fast is the internet connection that tablet uses, and how much free storage does it have?
If you press Install once and then leave the tablet completely alone for 20 minutes, does anything change?
For the Android system update: the display app restricts OS updates to between 00:00 and 02:00, so the tablet never reboots while someone is using it. Could you leave it powered on overnight and let us know whether it installs by itself?
It is only on the Lenovo tablet that it does this, If I view it on other devices it shows up in dark mode. But the table that is in my van to monitor the vehicle pv system seems to be stuck in light mode for the victron screens. I have cleared things even thinking about wiping the tablet and starting anew with it. This happened with the latest update.
Yep Lenovo has more issues, but Motorola as well, but I’m trying next week to get my hands on one to see for myself…this as some customers are not “schooled” enough we understand…
As Perez tells us every time, of course, he needs proof, so take of each step you do a photo and place it here…
I got a 60" Toshiba TV (as so many other brands as well) doing just fine for example…
Hi and sorry for the late reply @jperez. Vacation
1: There is absolutely no message. I tried it multiple times with and without reboot. Pretty sure, there is no message, not even for a very short time
2: The internet connection is fast (200 MBit with very low latency). Close to the AP. Storage free is 21GB out of 64GB
3: Nothing happened in the days, when I wrote the first feedback but I can give an update now
Update 1:
It now offered V1.4. Again, no visible reaction after I press “Install”. But, after leaving it alone for a while and maybe after a reboot (I wanted to try “install” again after rebooting the tablet), it’s now on V1.4. Seems to work smooth without errors
The OS update is still blocked. It stays on Android 15, One UI 10
Update 2, Oct 26:
With 1.4 everything seems to be solved Yippieh
The “Touch is on” message after every wake-up is gone
The starting page is always correct
Wakeup is really fast now, love it
The blocked OS update to Android 16 is not an issue anyway
