Android GX Display v1.4 released
Update: v1.4.1
One change: better detection of a page that failed to load, and better recovery from it.
Hi all,
Version 1.4 of the GX Android Display app is available. It is a maintenance release and
finishes the job v1.3 started: the blank screen after waking the display, which v1.3 was
meant to fix and did not. There are no new features.
How to get it
Displays with automatic updates enabled will install it by themselves during the night.
To update straight away, open the configuration menu by pressing and holding the lower
left corner of the screen for five seconds, then use the manual update check.
Changes
  • Fixed the screen staying blank after being turned back on.
  • Fixed the error screen staying on the display after it had already recovered.
Feedback
Please report any problems in this thread, and include the tablet model, its Android
version and the GX device you are using.
Trying to install v1.5beta 2, tablet confirms “ update download successful “ then a few seconds later an error is returned as per the image…….
Galaxy Tab A9+
One UI version…8.5
Android version…..16
GX cerbo mk2 running v3.81
Due to some changes in v1.4, the upgrade path to v1.5 beta was broken. We’ve recently released v2.0beta1, and upgrading to the beta should now be possible.
I am unable to install Anrdoid GX Display v1.4 via the QR code method.
Samsung Galaxy Tab A9+
Android version 16 with 6 August 2026 patch level
GX device: CCGX
It gets to the “Getting ready for work setup…” screen but then after sitting there for a fair while (approx 3 minutes) it then fails and says “Something went wrong”
Any ideas?
Does the QR code method in manual: 2. Installation directly install the latest version 1.4?
The QR in the manual points at the current release, so it installs v1.4.
We see this on a minority of devices and, as far as we can tell, the cause sits outside the app:
the same model provisions normally in most cases and refuses in others, with the same QR and the same firmware. What the device reports is always the same unhelpful Something went wrong, so there is little to go on from our side.
The same result can be set up from a computer. It installs the app and makes it the device owner, so the display ends up in kiosk mode exactly as the QR would leave it. Instructions below.
Prerequisite
The tablet must be freshly factory reset and sitting on the initial welcome screen, with no Google account and no Wi-Fi configured. If it shows an error screen, reset it and start again.
Step 0: install ADB
On Windows. Download the official Android SDK Platform-Tools from
https://developer.android.com/tools/releases/platform-tools and extract the ZIP somewhere simple, for example C:\apk.
On Ubuntu. Install it from the archive, together with the rules that let a normal user talk to
the tablet:
sudo apt update
sudo apt install adb android-sdk-platform-tools-common
Log out and back in after that, so your user picks up the plugdev group. If you prefer the
official build, download the Linux ZIP from the same address above and extract it, for example to ~/apk, then call it as ./adb from that directory.
Step 1: enable USB debugging on the tablet
On the welcome screen, go far enough to reach the settings without setting up any Google/Samsung account, just skip those steps*, then open Settings, About tablet,
Software information, and tap Build number seven times to unlock Developer options. Go into Developer options and turn on USB debugging.
Step 2: download the app
Download the APK from https://updates.victronenergy.com/feeds/android-gx-display/gx-android-display.apk and save it next to ADB, as C:\apk\gx-android-display.apk on Windows or ~/apk/gx-android-display.apk on Ubuntu.
Step 3: connect and run
Connect the tablet by USB. If it asks to allow USB debugging, tick Always allow and accept.
Then open a terminal, go to the folder holding the APK (cd C:\apk on Windows, cd ~/apk on
Ubuntu) and run:
adb devices
adb install -r gx-android-display.apk
adb shell dpm set-device-owner com.victronEnergy.gxDisplay/.DeviceOwnerReceiver
adb reboot
adb devices should list the tablet followed by the word device. The install should answer
Success, and the device owner command should answer
Success: Device owner set to package…. After the reboot the app starts in kiosk mode, the same as a QR installation.
Two things that can go wrong here:
  • adb devices lists the tablet as unauthorized, or on Ubuntu as no permissions. The first
    means the dialog on the tablet has not been accepted yet; the second means the udev rules are missing, which the android-sdk-platform-tools-common package above installs. After installing it, run adb kill-server and plug the cable in again.
  • The device owner command fails with a message about accounts already existing on the device. That is the restriction above: factory reset, skip the account and the Wi-Fi during setup, and run the commands before anything else is configured.
I have two suggestions regarding the GX Display app.
Is it possible to set a screen timeout and a sleep timer?
Is it possible to change the PIN after setup?
Beta version 2.0.1 of the app works very well on tablets, such as the Galaxy Tab Active 3 and 2.
Keep up the good work!
“Fixed: The screen stayed black after switching it back on.”
My tablet has been showing this bug since V1.2.
The bug is still present in V1.4.
However, after waking the screen, it isn’t black but shows the app’s grey background.
A long press in the bottom-left corner of the screen, followed by clicking Reload, fixes it.
Thanks and regards
Thank you very much @jperez for the instructions on manually installing the app in kiosk mode. I really appreciate your help. I have been unable to install the app in kiosk mode on this tablet since April this year.
I much prefer this method than the QR code method at this gives me the control to just get the job done. I was able to successfully get the app installed this way and put the tablet back into everyday production use. I will always use this method in future.
I think this method should be added to the manual as a alternative technical route to getting the app installed in kiosk mode.
The step to install the gx-android-display apk (adb install -r gx-android-display.apk) failed with the tablet putting up a dialog saying something like “Google Play Protect has prevented the installing of this app” which is likely what the QR code method was running into when it failed near the end but hid the error message. To resolve this I needed to disable Google Play Protect by doing the following: open Settings → Security and privacy → App security → Google Play Protect, tap the settings cog icon at top right, turn off “Scan apps with play protect”, confirm turning it off, after doing this I was able to install the app using the adb install -r gx-android-display.apk command.
Is the gx-android-display app digitally signed? Is there a way that the app can be signed so that Google Play Protect will allow the app to be installed without having to disable it? I did not give the tablet wifi access at any point of the install and did not sign into any Samsung or Google account so Google Play Protect was not connecting to the internet.
Here are the very detailed full steps I took to get the app installed for anyone else that this will be useful for
Steps to manually install Victron GX Android Display app and put device into kiosk mode to achieve same outcome as QR code install method
  • this alternative install method uses a computer with adb (Android Debug Bridge) and is suited for technical users
  • turn on the tablet by pressing power button for 5 seconds then letting go
  • go through tablet setup flow
    • click start
    • agree to End user licence agreement
    • agree to privacy policy
    • tap Agree
    • choose Setup manually
    • choose Turn off Wi-Fi
    • tap Skip
    • confirm you want to skip wifi setup
    • Copy apps and data
      • tap Don’t copy
    • Date and time
      • confirm date and time are correct
      • tap Next
    • Protect your tablet
      • tap Skip
      • tap Skip anyway
    • Google Services
      • turn all off
      • tap Accept
    • Samsung services
      • turn all off
      • tap Agree
    • Choose your display mode
      • tap Next
    • You’re all set up!
      • tap Home
  • change device settings
    • Settings
      • About tablet → Software information
      • tap Build number seven times
      • Allow development settings
        • tap OK
        • it should they say “Developer mode has been enabled”
      • Developer options, this will now be visible at the bottom of the Settings sidebar
        • scroll down to the Debugging section
          • enable USB debugging
            • Allow USB debugging?
              • tap OK
      • Display → Screen timeout
        • set to 30 minutes while we do the install
      • Security and privacy
        • App security
          • Google Play Protect
            • Settings cog at top right
              • turn off Scan apps with play protect
              • Turn off
              • this is very important, without doing this the app will fail to install via adb
      • Advanced features
        • Side button
          • Long press
            • choose Power off menu
  • Download the Victron Android GX Display app .apk
  • install adb (Android Debug Bridge) on your computer
  • make a directory for the .apk
    • mkdir ~/Downloads/victron-android-gx-display
  • mv the .apk file in there
    • mv ~/Downloads/gx-android-display.apk ~/Downloads/victron-android-gx-display
  • prepare the tablet
    • turn the tablet off
      • press and hold the power button
        • tap Power off and Power off again
        • turn tablet on by holding power button until it starts turning on
  • unlock the tablet to go to the home screen
  • connect tablet to computer via USB-C cable
  • the tablet should pop up a dialog asking for confirm connection to computer via USB
      • tap “Always allow from this computer”
        • tap Allow
    • it is very important that this dialog pops up and is accepted, otherwise the next steps will not work
      • this dialog did not show up after enabling Developer mode and then USB Debugging, I had to turn it off and on again first, which is why I have written that into the above steps
  • open a terminal on your computer the tablet is connected to
    • list devices using adb
      • adb devices
      • that should return something like DEVICE_NAME device
      • where DEVICE_NAME will vary depending on what device you are trying to install on, most important is that it must have "device” at the end to be able to continue, if it does not it may say unauthorised which means the Allow USB dialog was not accepted
    • install the victron gx-android-display application
      • adb install -r gx-android-display.apk
      • it should say
        • “Performing Streamed Install”
        • “Success”
    • next we want to tell the tablet to only run the victron app on boot
      • adb shell dpm set-device-owner com.victronEnergy.gxDisplay/.DeviceOwnerReceiver
      • command should return
        • “Success: Device owner set to package com.victronEnergy.gxDisplay/.DeviceOwnerReceiver”
        • “Active admin set to component com.victronEnergy.gxDisplay/.DeviceOwnerReceiver”
    • reboot the tablet
      • adb reboot
  • disconnect the USB-C cable from the tablet while it is rebooting
  • I found that when it first rebooted it went to home screen as normal and did not auto start the Victron Android GX Display app
  • if this happens, turn the tablet off then back on again
  • it then booted up and said getting tablet ready
  • then it launched the Victron Android GX Display app as expected
Can you confirm whether this issue is fixed for you in v1.4.1?
bugfix confirmed with 1.4.1 :wink:
2026-10-22T23:00:00Z
Good evening,
I got hold of an owner with Motorola…smart enough to install himself…
But only through the GX, not possible through his router…
It installed 1.4 without issues but upon powering up again it keeps asking the internet password, any ideas?
Regards, Jeroen.
Does it automatically ask for the password or does it happen when you try to join a WiFi network? Please note that there are two ways to connect to WiFi. Via de WiFi tool in the “secret menu” and via regular Android settings. Have you tried both?
Thanks for reaching out.
I have followed all steps and got all expected “successes” then I typed in “adb reboot” which restarted the tablet, but it went to home screen like you experienced, so I powered off and back on… same thing, home screen. I factory reset the tablet and tried all steps again… but still reboots to home screen.
Happy to provide more information if needed… super keen to get this sorted.
EDIT: So, although it continued to boot into home screen, I decided to go find where the adb installed the app, once found I clicked on the app to start it up, then I rebooted the device and it now boots up into Kiosk Mode. GREAT SUCCESS!!
Good work! Okay, hmm, I am glad to hear that! Thinking about it I think I may have tapped on the app too to see what would happen while trying to figure out why it wasn’t working! So that good to know, should probably add to the list of steps :slightly_smiling_face:
It is definitely very satisfying when it boots up in Kiosk mode!! :partying_face:
