The below document explains the key differences between the different GX devices -
And this has more detail on the underlying board hardware if you are interested in that -
It’s important to note the internal GX card in the EasySolar II GX is not a Cerbo, they are distinct boards and there are quite a few differences which those documents cover in detail. To answer your specific questions:
There is no HDMI port on the EasySolar II, you are limited to the 2×16 character display (Though there is now the option to use an andriod tablet as a display - NEW: Use an Android tablet as dedicated GX Wi-Fi Display (beta)).
There are separate images for each hardware option, though I believe these two devices have feature parity other than options related to specific hardware differences (displays, relays etc). Both can run Venus OS Large.
No, the EasySolar II doesn’t have an SD card slot.
