I have had just over a year of use of our new Victron installation on our 55’ motor yacht and about a week after returning from a trip I started getting weird errors on my Cerbo GX display and now after several reboots of my MPII’s I think I have an internal error that says I should contract Victron for support. Hoping sharing the details here someone can confirm my best course of action to fix this.
For reference high level diagram of my components. Boat has 24VDC system and we take 240Vac from shore power so each MPII gets a 120Vac leg
Boat is now docked in my backyard on shore power so in theory little to no load on the inverters. Late this past Thursday night I started getting VRM alerts about an overload on L2 and then a loss of Time Synchronization and device cannot transmit data:
I didn’t discover these until the next morning so I came down to the boat and started investigating. The LED’s on the front of both MPII’s were flashing different codes and I looked them up and came to the conclusion the best first step is to reboot both MPII’s. I had one MPII flashing bulk and float LED’s and the other flashing all three bulk, absorption, float LED’s. I got my MKIII device out and my laptop and tried to connect to second MPII as it has an open VE.Bus port for the MKIII so I leave it connected. At first I couldn’t connect even though I have used this port before to program both MPII’s.
When I launched the VE.Bus System Configurator it said nothing else should be connected to I removed the RJ45 connection from my first MPII and plugged the MKIII device in that port and am able to connect and see both MPII’s and their configuration appears correct:
System Check shows OK for both MPII’s and the asterisk tells me L1 is the Master and L2 is the one I’m having a problem with:
I rebooted both MPII’s a couple of more times and now have the first one flashing just Bulk which I believe means it can not be a Slave. And the second MPII is still flashing three bulk/absorb/float LED’s and has a steady low voltage light but I have 26.5Vdc. I think the low voltage is a false flag as one of my Lynx Smart BMS’s is beeping continuously. The battery SOC is 36% and I have an auxiliary battery charger now charging the main house bank.
Am I correct to interpret 3 flashing as Internal error?
I don’t have a picture of my first MPII but it has just the Bulk LED flashing and I think this table reflects “cannot function as a slave” as the problem IF the pictured indicators in the table below are supposed to be flashing. The last one Code 26 seems like root of my problem and IDK who/how to contact Victron for support on this and could use some input. Anybody know what type of failures these MPII’s typically exhibit? To me it seems like it’s a CPU or communication error on the main board. Hoping a simple board swap would fix it vs having to uninstall re-install a new unit.
When I first came to the boat I saw this flashing on the first MPII and the time sync error in the Cerbo. It’s confusing that error code 10 in the table below appears to be flashing but the error codes above seem to indicate steady state not flashing and my LED’s are flashing.
Additional data points I keep seeing a time sync alert appear in the Cerbo making me think it’s a communication issue between the MPII’s but after several reboots I noticed I have 3 active alerts. The first not all devices found makes sense as my second MPII doesn’t seem to be communicating. The Low Battery Alarm is a red-hearing IMO as the battery SOC is upto 45%. The High DC Ripple warning has my puzzled as to what that is/how it’s detected etc. Boat currently setting idle at the dock, no engines running and the aux 24VDC charger is on bringing the batteries back to 100% SOC since it’s overcast and my Solar is not producing enough to charge the batteries…
Scott in Sunny FL aboard M/V MARIAH
