Operating MultiPlus without a battery
Is this even possible?
How can I operate the MultiPlus 2 without batteries, powered only by shore power?
The idea is to control the amount of power drawn from the GRID. This
is then passed on to the inputs of several other MultiPlus 2 units connected in parallel.
Thanks for your help
Johannes
Hi, welcome.
There are numerous topics on this subject available via a search.
The answer is no, they are not designed to run without a battery and you absolutely should not try to do this either.
How is the MultiPlus supposed to do that?
It is usually off. The Cerbo-GX switches it on via a relay connected to the main system (an off-grid system with no connection to the grid) when the SOC reaches 30%, and switches it off again at 60/70%. So, something like a generator. The input current is simply passed through.
The input current can be controlled from 6 A, which has its advantages. The home system runs with “PowerAssist”, which is useful during power surges.
The advantage is that it can be automated WITHOUT any additional devices. I still have the MultiPlus-II lying around and can control things better with it than with an
isolation transformer. It worked perfectly with the isolation transformer, but it’s always a bit tricky because the current can’t be adjusted.
There is nothing that multiplus can do that the parallel system couldn’t also do.
Typically this is just done on a cerbo with nodered, ignore AC settings or assistants.
You do not need to add such unsupported complexity to achieve your goal.
I don’t use Node-RED! The Cerbo GX can handle that on its own, using its relays.
See Cerbo-GX - Multiplus-2:
(in this image, there are 3 in parallel, so 18A; one can be set to a minimum of 6A)
You don’t need to, it is just one of the various options.
It provides the greatest flexibility for more complex automation logic and integration into VRM, the remote console etc, but it isn’t a requirement.
But adding another MP2 to achieve this seems counterintuitive, battery challenges aside.
(it is also not supported to share batteries between different, independent systems).
Hi Nick,
Thanks, I’m somewhat familiar with Node-RED from what I’ve read. I don’t use it for anything, though—perhaps I will later on, once I run out of other things to do. It’s surely a great system, but for the moment, it’s a bit too complex for me.
Using the power assist feature… This requires somewhere for the power to be suplied from to supplement a.limited input That would be a battery.
Why not add some chargers like the phoenix that charge from shore power (no AC pass through.) That just make use of the available input limit. Then you can be assured of keeping the shore limit.
These have remotes on offs can be wired to the cerbos remote and switched on and off either manually or even with the generator start stop. No fancy programming. Unless you want to dig in there
I hear you. It’s something that is daunting at first, but when you get your head around it, you can’t imagine how you managed without it :slight_smile:
When you are ready, lots of resources to help get you started.
Alternatively this can be used but it must be connected either it’s own bank or to the main bank and also use the gen start stop or manual relay.
Hi LX,
Thanks for the suggestion, but I still have the Multiplus-2 here; I’d need to get the Phoenix.
Hi Nick,
Thanks for your effort, I got the hang of it pretty quickly. The first programming language I ever learned was assembly for the 8085 processor.
After that, C. Anything that gets more “complex”, like C++, becomes too opaque for me. I don’t use it. Anyone with access to the libraries can do nasty things with them. Just look at PHP at the moment…
Hi LX,
Regarding the system:
The home system (main system) has a large battery, which is charged using solar power. In winter, when there’s snow on the panels, I still need electricity. This would come from another system, limited to 6–15 A. A MultiPlus-2 or an isolation transformer (I have both here, so I don’t need to buy anything). I’d enable PowerAssist on this system, not on the “charging MultiPlus-2”. When switched on, it only supplies 6–15 A from the GRID, depending on what I set.
No, it simply can’t do that.
How is it supposed to limit the current?
The Multi just has relays that connect the input to the output.
To prevent the set input current from being exceeded, the Multi adds power from the battery. That’s PowerAssist. But it needs a battery for that.
If the Multi doesn’t have a battery it can draw on, the required current is simply passed straight through, 1:1.
Hello Mathias,
Thanks for your reply! I hadn’t read it that way in the manuals, or perhaps I hadn’t understood it that way.
So that’s clear: it won’t work properly without a battery! That settles the matter and answers my question.
This is what I love about the VictronCommunity! Thanks to everyone else for your help.
Best regards
