yesterday I installed a new Smart Shunt IP65 300A to my Multiplus II GX without any problem.
After I was finished I disabled bluetooth on the Smart Shunt (yes I know…) and everything worked fine the whole day.
Today I had to do a zero volt calibration on my BMS and because of that I powered off the Multi and switched off the battery main fuse.
After I switched everything on again everything looked ok, but the shunt stopped reporting after a few minutes and has not reported back since then.
All components are running latest firmware.
I tried following things:
- Removed smart shunt from power for >5 minutes (ve.direct cable + power cabel)
- checked cabling
- replugged all cables (I am using a 0.9m ve.direct cable)
- I checked the fuse in the power cable of the smart shunt - everything OK
- rebooted the GX part
- powered off/on the whole multi
Tomorrow I will check with a ve.direct USB cable but I am really puzzled.
Any Idea what I could still check or how to diagnose this?
Does someone know which log file I could check to see more informations of the ve.direct connection?
Not sure whether our MP-II GX is representative but it is extremely finickity about the length and quality of the USB part of the USB to VE-Direct cable. Certainly some EMI sensitivity issues there so keep the USB cable as short as possible, 30cm or less even. The VE-Direct (part of the) cable is basically just rs232 and can be as long as you need.
Hi @UpCycleElectric, thanks for your response.
currently the connection is not using USB - I am connected via the cable from the Smart Shunt IP65 and a 0.9m ve.connect cable (shortest available) what I have seen. Weird thing is that it worked without problem and then stopped after today’s power cycle.
In the off-chance there might be a hardware issue with the ve-direct connection on the MP-II GX end, there is a secondary connector inside the casing you could try.
I will check if it’s on the shunt or the multi side tomorrow with a ve.direct to USB adapter. Depending on the result I will try the internal port. Thanks for the tip.
Easiest way to test the Smartshunt, if you have an in USB to VE-Direct cable, is to use your phone or tablet with victronconnect app. And maybe an USB-C adapter.
Seems the smart shunt is dead. I tried to connect from my MacBook via ve.direct USB cable but VictronConnect does not find anything. Seems I have to replace the smart shunt… very weird after just one day of usage…
Actually, even when failures are very rare, if they happen it’s is quite common to do so very early on in operation: ‘Dead On Arrival’ failure.
The Smart Shunt indeed was completely dead. After I exchanged it to a new one everything is working fine again.
