Multiplus II GX LAN failure due to bad WiFi
I recently moved my Multiplus II GX into a server rack and grounded the rack.
Quite logically this made my WiFi reception really bad.
Because LAN is the main connection I did not expect any issues, I just assumed that WiFi could be used as a backup.
The next day I was greeted with a email warning that communication to VRM was lost. From Unifi logs I concluded that both the WiFi and LAN connections were dropped by Multiplus II GX. I could also see in the logs that the WiFi connection was lost multiple times per hour for a few hours.
To me this seems strange as the LAN connection is extremely stable. So my conclusion was that the fallback mechanism between LAN and WiFi does not work.
I rebooted my Multiplus II GX and disabled WiFi and it has been stable for roughly a week now.
This situation is fine for me but I wanted to share this information because it might highlight an issue with network manager in the GX device.
notes:
  1. The Multiplus GX II screen did not show any signs of error/warning. I would have expected a warning because it has lost connection to its power meter (vm-3p75ct). I think it was just in ESS-passthrough so the GX device was likely still running (not sure?)
  2. Interestingly the ‘uptime’ for the LAN port seen in Unifi did not reset which might mean it never lost physical ethernet connection only ip layer connection.
