MultiPlus-II GX 48/5000/70-48 Firmware Upgrade v502 -> v556
I want to upgrade the firmware as you can see it is very out of step. But I am nervous af.
The highlighted is what worries me … I am not familiar with these tools and do not want to break this blue monster on my wall.
Can someone teach me Greek so i can better understand the instructions?
Unless there is a specific issue you have with the current firmware, Victron recommends you leave it alone. Simply being out of date is not a reason to update complex hardware like the Multiplus.
Every update fixes bug and/or brings new features…
But that doesn’t mean that every system needs that fixes or features.
@CharlieMTF If you are unsure, don’t do it or ask some to help you locally.
Reading links:
VE.Bus is over 20 years old (an based on the even older VE9bit).
No one could think about what would be possible 20 years later.
Don’t you think Victron would have made the update process easier if it would possible?
Adding new features requires to manually check and adjust the settings after the update.
The new features for the German gridcode use the AUX 2 input and if you already use AUX 2 for something else you have to adjust the settings.
