Can the Neutral be connected to both the AC in and AC out to ensure that there is no floating voltage on the Multi Plus II? (ESS configuration)
Depends on your gridcode and local regulations.
Hi Matthias thanks for the reply don’t know if this helps but it is an Australian grid code I will have to see if I can find out more. So it can be done? and do you know if the there is a floating voltage?
