Multiplus 2 GX T-Sense use it for?
Hi, i have a Multiplus 2 GX and i have the “T-Sense” Tempreture Sensor, if i connect it can i use it for any kind of tempreture reading? like for environement tempreture or is it only for battery temp? if yes how can i use it for battery temp if i have a smartsolar connected to it?
thanks in adnaced
  • matze
The multi’s temp sensor can only be used for measuring battery temp, as there is no way to get at the temperature reading, or to get it to switch a relay..as far as I’m aware…
