In Off-Grid situation (no AC-In), can we use ESS programmable relay to activate AC-Out2 according to the state of charge of the battery pour feed AC-Loads from the battery?
The AC 2out is programmed with a different assistant caled the programmable relay assistant.
ESS assistant is used for grid connected systea to prioritise battery and solar over grid (both happen automatically when you are offgrid
There is not much in the documentation, but you can open ve configure in demo mode and play with the wizard before you try it on the live system
