So I have a total of 4 of these sensors.
One magnetically attached to a diesel tank always worked great.
The gray tank sensor I need to run a Bluetooth dongle closer to it. When it’s full of water the signal doesn’t make it.
The gasoline tank is very not LOS I think the Lifepo4 batteries block its signal. Sometimes it reports a sensor value sometimes it doesn’t.
Now the one that puzzles me most. I have a small 2 gallon coolant tank for a hydronic heating system. I installed the sensor and it worked fine out of the box. Now it’s still connected and reports a sensor value in the mopeka app on iPhone but does not report a sensor value in victron.
In the setup tab of the options for the sensor on the Cerbo GX normally at the bottom it reports sensor value in cm. My gas and hydronic ones don’t report the sensor value even though it is in the app.
Can I get around this with node red?
