Mopeka won't show values on cerbo gx
I have read all topics and solutions about this issue, but I am overlooking something I guess.
I have a mopeka tank sensor on Bluetooth and works fine in the mopeka app.
I configure it on the cerbo gx, it shows the diesel tank but not the value.
What am I doing wrong here. Updated the firmware, rebooted the cerbo several times, put the power completly off, but it stays on 0% instead of 70% on the mopeka app.
Ps. The watertank in empty, so I assume that’s correct.
Please help.
As it is reading the battery voltage and temperature it is reading the Mopeka sensor OK. I am no longer using guiV1 so I can not recall the info you see. Can you see a level reading on the GX screen and is this in the correct 5cm to 50cm range. Do you have the same range set on the Mopeka app.
The only other thing that I can think of is what type of Mopeka do you have, the Pro or the Universal and what firmware do you have on the GX device. Support for the Pro Version was added in V2.90 but support for the Universal was not added until V3.14. Do you have a Universal and Firmware older than V3.14.
Thanks for your reaction.
The 5-50cm is the same in the mopeka app.
I have the mopeka pro version. Firmware version 0.1.33
Firmware version on the cerbo gx is V. 3.65
So far it should be good.
Have you tried the gui2 display to see if that picks it up. I find it odd that the screenshot shows the % butane for “fuel”.
I have set burane to 100%, reboot the cerbo, but still 0%.
How do I activate gui2?
From memory of the old gui, it is in Settings, Display and Language, User Interface and select gui2. If you don’t like it then you can go back to gui1 in the Display Settings.
thanks pwfarnell . ill try that tomorrow. :ok_hand:
Setup the gui2, but unfortunately the result is the same.
The final thing I can suggest is to update the Cerbo firmware to the latest release.
Thanks for the suggestions, but it’s already on the latest firmware 3.65
I really hope some victron engeneers pick this up, because I really think it’s a software or firmware issue.
