Okay, it’ll be a little while before I can show you the installation, but I can describe it roughly. It’s installed on an overland truck, and I’ll just start at the top:
There are 7 panels on the roof, arranged as 2 separate systems, plus 1 panel on each of the sloping roof sections; both of those can be tilted towards the sun:
Solar array 1 consists of 4x Reno 225 Wp panels connected to a SmartSolar MPPT 250/60 Tr
Solar array 2 consists of 3x Topunive 100 Wp panels connected to a SmartSolarMPPT 100/15
Solar array 3 consists of 2x Offgrid 165 Wp panels tilted at 45°, connected to a SmartSolar MPPT 75/10
They’re all “flexible panels”. The ones lying flat have 35 mm of rear ventilation, and each solar array has a load switch before the MPPT.
Moving on to the “basement”: the MPPTs are installed here and feed a Multiplus II 3000/24.
The power goes into a modified EEL battery as a 24-volt system with 8 324er GATL cells, giving 8.24 kWh, including heating and a JK-BMS.
There’s also a shunt, a Gerbo GX/ 50 and an Orion TR 24/12- 15 installed.
As for the loads, everything in the cabin, including the fridge, runs on 24 V, except for a few USB charging sockets.
I need 230 V for the induction hob and the 750-watt heating element for the hot-water boiler, an air-conditioning/heating unit, and the socket for the laptop. There are also sockets for things like the e-bikes.
I’m always happy to answer questions or hear ideas and input.
Udo
