I’m not sure if the MK3 does this too, but when reading the AC frames from a Mk2/usb, with two parallel MP3000 inverters, the AC current reported is the double of the actual current(TBC)(, rather than the sum of both). The DC frames are fine.
Related topics
| Topic | Replies | Views | Activity | |
| Leerlaufverbrauch mp und mp2 in verschiedenen betriebsmodi abweichung vom datenblatt | 6 | 84 | 11 April 2026 | |
| Verbrauchswerte in der Console/VRM stimmen nicht | 9 | 290 | 28 November 2025 | |
| Incorrect current readings on Parralel Multiplus setup | 0 | 27 | 4 January 2026 | |
| 2x MP 800VA parallel über gemeinsamen Akku als Mieterstrommodell (AC-AC-Kopplung) | 2 | 188 | 1 January 2025 | |
| Messgenauigkeit Victron Multi am AC OUT 1 | 8 | 106 | 4 April 2026 |
