My Cerbo GX MK2 no longer detects the VE.Bus
I built my installation myself: 3 MultiPlus 2 5KVA units in a 3-phase setup, and a homemade 16-cell LiFePO4 battery with a JK BMS connected to the Cerbo via the CAN bus.
It was commissioned without any problems and had been running for a few weeks. Yesterday morning I noticed that all 3 MultiPlus units had their red low-battery LEDs lit. The Cerbo is in the meter cupboard because the 2 ET340s are connected to its USB ports. The VE.Bus connection between the MultiPlus units and the Cerbo is a shielded CAT6 cable. The Cerbo is powered externally in the meter cupboard by a 230/24 volt DC converter.
After noticing that all 3 low-battery LEDs were red, I went to the meter cupboard and found that the VE.Bus cable had come loose from the Cerbo. After reconnecting it, the MultiPlus units would no longer come online.
VE.Bus is missing from the device overview, so the MultiPlus units are no longer detected by the Cerbo. First, I used a laptop and a USB-VE.Bus interface MK3 to check whether the software was still present in all 3 MultiPlus units. It was still present on all of them, including the ESS assistant. Just to be sure, I reloaded the backup files onto the MultiPlus units.
Then I connected the USB-VE.Bus interface MK3 to the Cerbo, and now the Cerbo can see the MultiPlus units. However, they do not start up; the ESS function is unavailable, and I get a message saying that the ESS wizard is not present. On site, I tried connecting the L1 MultiPlus to the Cerbo using a short VE.Bus cable to rule out a cabling fault, but the Cerbo still could not see the MultiPlus via VE.Bus.
Does anyone have any advice on what to try next?
Start by not powering the cerbo via AC. It should be powered directly from the battery.
Thanks for your reply. I’ll connect it tomorrow morning, although it’s been running without any problems for about four weeks.
Have you checked the battery voltage? If the MPs all signal low battery voltage then maybe the battery voltage is indeed low.
Have you tried powering down the whole system, so switching off both Cerbo and the MPs?
Battery voltage is 52.2 V. I’ve restarted the MultiPlus units and the Cerbo several times, but VE.Bus doesn’t stay visible in the device list.
How long is the VE.Bus between the Cerbo and the last MP? Have you tried moving the Cerbo closer to the MPs. Just for a test, doesnt need the ET340s to be plugged in.
Have you tried plugging in the Mk3 Adapter into one of the Cerbos USB ports, while the Mk3s VE.Bus is connected to the MPs? It should recognise them the same as your PC does. ESS wont work correctly like this however.
There have been issues in the past with a few Cerbos and their VE.Bus, but i cant remember the details. I thought it was about not being able to turn them on anymore over the Bus, but not connectivity in general.
Well, I made a really silly mistake, in hindsight. In the dark, I plugged the VE-Bus cable into the CAN port, which is why I wasn’t getting any VE BUS communication. I learned something, though: if you connect the VE bus using the MK3 converter to the USB port on the Cerbo, not all assistant functions work any more. I also found that the Cerbo works perfectly well in the electrical cabinet with a 230/24 V DC power supply. I’m not connected to the output of the Multiplus. I also learned that you can program the Multiplus quite happily with a small 30 V DC power supply. This topic can be closed.
