Hello everyone,
I’m trying to resolve a communication problem between my MultiPlus-II 48/3000/35-32 and Venus OS (running on a Raspberry Pi) via an MK3-USB interface.
Here’s the context and what I’ve done so far:
Hardware: MultiPlus-II 3000, Raspberry Pi (latest Venus OS), MK3-USB. (Note: battery data comes through the CAN bus without any problems; the issue is purely on the VE.Bus side.)
Original problem: I discovered that the battery had stopped charging and discharging, and saw that the MultiPlus was no longer available in VRM either (last seen 14 hours ago).
Fixes tried:
Replaced the network cable and tried tested network cables.
Replaced the Raspberry Pi’s power supply (the Pi was showing an undervoltage warning).
Connected via VictronConnect. It didn’t detect the MultiPlus, but a forced firmware update to v568 reset everything to factory settings.
However, I still can’t establish a connection. I can’t connect with VE.Config either: it does connect, but shows lots of pop-ups about “incorrect” settings and ends with a communication error (communication error).
I used VE.Flash to downgrade the firmware by one version, but got the same result.
Current situation:
So I can update and downgrade the firmware, but afterwards I can’t connect to change the settings.
Does anyone have any other ideas about what I can try?
