Lynx Smart NG BMS monitoring
Howdy Guys,just finished installing two 300 AH NG Lithiums in parallel config and a Lynx NG smart BMS, have it all configured using DVCC,Inverter/charger is a Multiplus EasySolar, all working a treat,but just wondering if deeper parameters such as cell voltages/temps etc can be seen directly via VRM/Cerbo or must one still bluetooth the actual BMS for that info,i might be missing something simple in the menus ?
Here is how to get them on a GX device, you choose battery 1 or battery 2 and can only see 1 battery at a time. I also have 2 x 300Ah NG batteries.
They are not set as parameters in the Advanced page, custom widget in VRM so you can not see them, n st the min and max of all 8 cells. In Node-RED, brief investigation has shown you can read 4 cell voltages which I believe will be from the battery selected for display on the GX device but I have not followed this through definitively. These values could be read and transferred to virtual batteries which would then be recorded and displayed in VRM. What might be interesting is if Node-RED could be used to swap the displayed battery on a say 60 second cycle and write the 4 cell voltages alternately to 4 out of 8 virtual batteries.
