How much battery info should be displayed on the Dashboard or Remote Console. So far, mine only shows quantity of batteries and total capacity. The other info seems to be front one battery or an average. I am using 2 each SOK 12.8v314AH batteries which are daisy chained to the Cerbo VE. Can Port 1using can-bus BMS-LV, 500kbit/sec setting.
Side question: what are the 2 ::2, 1 ::4, etc, designations below?
It is, there is no need for the GX to track every BMS metric, it would make the CAN spec and comms busier. Ultimately, that is what BMS tools are for.
The GX is showing a window into the BMS and the relevant metric is understanding if a significant delta is developing which is a guide to go dig a bit deeper. Ultimately the BMS will start generating alarms and taking action if a real problem exists. It will do that irrespective of how much information it is or isn’t sending. Temp and voltage min/max have been sufficient for all the commercial batteries, with VRM charting the various cell id’s as the state moves during charge/discharge. Too much information can also be counter-productive. Having diagnosed a few bad cells by now, can’t say I have regretted not seeing more cell stats. Battery manufacturer support generally can figure things out with this view as well, though, they do sometimes want data straight from the BMS if they need a broader view, something that the GX would never accommodate.
SOK advertises them as Victron-compatible, but a battery that sends only a fixed max charge current / voltage, regardless of cell voltages, doesnt make much sense
For example. I previously had a Victron switch installed close to the battery plus terminal. And it ran hotter (32°C) during charge sessions than after moving it. The heat generated by the resistance of the Victron switch, had a significant impact on the temperature. Now it’s only a matter of a few degrees higher than the other cells.
Many of the so called Victron compatible batteries (read: BMS) can be monitored with the help of NodeRED. I read the maximum temperature and voltage, and when that seemingly gets out of control, I either lower or stop charging altogether. Based on the values.
Similar DIY setup here, and one thing I’d add: with two banks, it’s worth checking in the device list that both batteries show up as separate services so DVCC aggregates them properly, and that the charge current limit from the weaker bank is the one driving the whole system. If you’re also using dynamic pricing or DESS, watch how the BMS-requested current limit interacts with the scheduled charging, since a hard limit can make the charge schedule lag behind. Backing off the current when the max cell voltage is reached is exactly the right approach to give the balancer time.
