LiFePO4 battery in Victron Energy system
Good day,
I’d be grateful for your advice, if possible.
I have a system on my boat with various Victron Energy components. These include a Quattro 24/5000, a Lynx Distributor, a Lynx DC Shunt VE.Can, a Victron Centaur 24/60, an Orion-Tr 24/12, an Ekrano GX, 800 Wp of solar panels and two 12-volt Renogy LiFePO4 batteries, each with a capacity of 300 Ah, connected in series to provide 24 volts.
I have three questions:
  • Can I have an expert connect everything without any problems?
  • Would it be better to buy two more of these batteries as an additional battery bank, as that would be better suited to the Quattro?
  • Do I need to buy any additional equipment to have a good system installed?
I’m asking in advance because my boat is still abroad, and I want to make sure everything is in order before I set sail for the Netherlands.
I don’t know anything about ships, but I’m missing one or more MPPTs.
That’s right, the solar panel system is also going to be upgraded with an MPPT, but new panels are needed and still have to be bought. Probably 4 × 400 Wp.
Please show some photos of your current setup and wiring!
Putting two 12V LiFePO4 batteries in series to get 24V is not recommended. This creates an imbalance between the batteries, which is corrected internally by the BMS in a 24V battery.
Thanks for your reply. I understood from the supplier that it would work, since they’re both 300 Ah. I’d just need to sort out the BMS differently, then. Has anyone else had any experience with this? Any information is welcome, and ideally, of course, a solution. :grin:
It will work so long as the batteries are designed to work correctly together when connected in series (and series/parallel), for example for battery balancing and disconnects – if they have internal BMS this normally means that they have to be designed to be linked together, one BMS acts as the master and the other(s) as slaves, and they have to be programmed to do this if they don’t detect the setup automatically.
Normally it’s not enough to just have the same model/size of battery in series, so I suggest you recheck this specific issue with Renogy.
Renogy clearly states the need to manual check and ballance of battery modules.
I would avoid such batteries and look for 24V modules with internal BMS or a manufacturer that offers a real series connectable modules, that does not require human intervention.
Clear answers, thanks for that. I’ll try to sell my current new LIFePo4 batteries and use the money to buy a suitable battery pack. Of course, I’ll first check with Renogy to see whether they have a suitable solution.
I have a little boat myself, with a Quattro 24/5000 too. What was your thinking behind the Centaur charger? Whether you’ll actually need one depends on how you use it, of course, but your Quattro can charge just fine too, you know :slight_smile: And, purely as a thought, if it’s a steel boat and you’d be connected to shore power for a long time, you could consider an isolation transformer. It’s not cheap, and it’s another box with wiring to install. I don’t have an isolation transformer myself because I almost never connect to shore power. I don’t sail much either, and you have a lot more solar than I do. So if you also charge from the alternator while sailing, you’ll rarely, if ever, be connected to shore power.
