Subject: Charging home batteries via V2L from an electric car (230V/16A) – which Victron charger?
Hello everyone,
I’d like your advice on the possibility of charging our home batteries via the Vehicle-to-Load (V2L) connection on our electric car (Alpine A290).
Our current installation consists of:
3 × Victron Multi RS Solar 48/6000/100 (three-phase)
4 × Felicity Solar FLB48314 LiFePO4 batteries, each with a capacity of 16 kWh (64 kWh in total)
A shared BMS for the four batteries, in addition to their individual BMSs
Victron Cerbo GX with ESS and Dynamic ESS (DESS)
Victron Lynx DC distribution
Grid connection of 3 × 25A
12.9 kWp of solar panels, divided between two AC-coupled SMA inverters
All loads and solar panels are connected to the AC output of the three Multi RS inverters.
What would I like to achieve?
Our Alpine A290 has a V2L connection that can supply a maximum of 230V/16A (approximately 3.7 kW).
I’d like to use this to charge our 48V home batteries, for example during an extended power cut.
My idea is to install an additional Victron battery charger that converts the Alpine’s 230V AC to approximately 48–57V DC, and then connect it to the batteries via the existing Victron Lynx.
This means the Alpine would not be connected directly to the 230V home installation. The three Multi RS inverters would continue to power the house as usual, while the Alpine would charge the home batteries via the additional battery charger.
I’m thinking of a charging power of approximately 2.5 to 3 kW, so that the V2L connection is not loaded to its maximum.
My questions:
- Which Victron battery charger would be most suitable for this? I’ve looked at the Skylla-TG 48/50, but perhaps there are better or more modern alternatives.
- Can a charger like this be controlled via the Cerbo GX, for example based on the batteries’ SOC and the charging limits communicated by the Felicity BMS?
- Can the additional charging current be included in the DVCC control, so that the total charging current from the solar panels, Multi RS inverters and additional charger stays within the BMS limits?
- Is galvanic isolation between the 230V V2L connection and the 48V DC side necessary or desirable?
- Are there any specific considerations regarding earthing, neutral-to-earth bonding and residual-current protection when using a V2L connection?
- Has anyone tried a similar setup where an electric car charges a Victron home battery via V2L?
I’d prefer a solution that integrates as well as possible with the existing Victron installation, so that the Cerbo GX and BMS can monitor the charging current and automatically switch off the charger if necessary.
I’m interested to hear your ideas, experiences and any suggestions for suitable Victron equipment.
Thanks in advance for your help!
