IP67 borked after firmware update
After attempting to update the firmware on my IP67, the charger is not functioning. Both lights flash and I cannot connect to it with the Victrononnect app. The device lost its name but it is visible via the app. I just can’t connect to it. Both the yellow and green lights flash continually. I need to get my batteries charged ASAP.
HELP!!!
Did you see this thread: IP65 update failed and this website
Yes. I have an IP67 which doesn’t haver a “Mode Button”. So that posting didn’t help me.
Hi Jon,
You can probably connect once you have removed/forgot the device in the phones bluetooth menu.
With kind regards,
Thiemo van Engelen
Hey Thiemo,
Yep I was able to reconnect after deleting the bluetooth entry on my phone and the entry in VictronConnect. I then was prompted to reinstall the firmware update. Then it failed again and then I repeated the process and then it finally completed the update. Then I column’t connect again and I repeated the process a third time and that finally worked and it stabilized.
Thanks very much for the great tip and hopefully this posting might help others.
jon
Hi Jon,
Good to hear that everything is working now.
With kind regards,
Thiemo van Engelen
