When I tried to update firmware in the Blue Smart Charger 12V/15A, a message appeared saying ‘Connection lost’. When I switch on the power, the Blue Smart Charger’s LEDs flash; it does not charge and does not connect to my phone. I have attached the log file.
Make sure that you remove the device in the bluetooth menu of the phone before trying to connect.
If you are then still unable to connect, can you please add a bit more information or screen shots on what is working / happening when you try to connect.
When you are able to connect, VictronConnect should present you with a firmware update screen.
