@Biff Checked settings>geneal>Date & Time but to me the UTC time is spot on, and the timezone is correct too: time zone -4,33 year [Alpha Centauri] ;o)
Okay, GX timestamp is a dead-end. I adjusted my GX date to June, and then to March, no difference - VRM uses its own timestamp. Next suggestion is to download the last hour of data from VRM to check their timestamps - if they are correct, but the graphs are not plotting according to time, then I’m more puzzled than ever.
@sunflower I experience exactly the same behaviour . I tried already all the advices with no luck.
I’m convinced that all your, and mine too, are right.
The problem occurred a month ago I think ![]()
I believe we have to wait for an update ![]()
Martin
@Biff I know how to download the graph data in the “advanced” section. But the problem I’m referring to is at the “dashboard”[note]. It seems to me that there is no download button in the dashboard.
[note] I don’t suggest that the same problem exist in the advanced section (didn’t checked). I don’t use the advanced section yet that often and when I look at it it seems to be just a data snapshot, so no updating, but I could be wrong.
@sunflower That’s very odd indeed, because the image that you provided in your original post is from the Advanced section. So go ahead and download a few hours of data from there and take a look at the timestamps in that data. If you stick with Last hour, it will download the spreadsheet directly.
Sorry, I’m wrong. It looks like Advanced graphs because you have no bars. So question is, are the Advanced graphs stuck too?
removed my original reaction
as Biff has already seen that the screenshot was and is from the dashboard.
I edit this post because I did made an incorrect conclusion after I checked the advanced section reports.
I first wrote that the advanced section seems to have the same problem, but after double checking I change my conclusion:
The advanced section reports seems to behave correctly.
Just FYI: below another screenshot of the VRM-dashboard (not advanced section) in this case from the opera-linux webbrowser.
Screeshot is from 16:30h but x-axis is show till 13:30h (13:30h was the moment that I opened the dashboard).
So after opening of the dashboard the graph it is not updated anymore (but a yellow datapoint is shown with actual and correct value - and is updated constantly).
And what a surprise!
Since a few day’s ago (I noticed it two day’s ago, but I haven’t watched it closely last weeks), the problem I had before, dissapeared.
This applies to Android VRM app and VRM website (in webbrowser).
Of course, in the mean time I got updates from Android, Linux and webbrowsers, so that could be the reason that the problem doesn’t exist anymore.
But I suspect that Victron has solved this issue in the VRM portal.
Now I see an update of the graph every minutes or so and that wasn’t te case before when the problem existed, it lacked this “refreshment” every minute.
So, thank you VRM team!
