today I finally finished my installation which is working almost perfectly…
The only problem I have, is that the dashboard of the VRM is not showing the right data.
When I refresh the page, the correct values for the soc and everything is shown but after half a second the dashboard switches to values from approximately half an hour ago. The remote console is live, as is the indicator on the top of the dashboard also shows real time connection.
Has anyone a solution for this somewhat minor problem?
Thank you in advance.
Julian
I’ve been having the same problems for a few months now. Sometimes it works after I deleted all devices from the VMR (data remains intact). Sometimes a restart of the Raspberry (Venus OS) helps. What kind of GX device do you have, or are you also using a Raspberry? I’m almost at the point of buying a Cerbo, hoping that the problems won’t occur anymore then.
