I have a Cerbo GX MK2 running firmware version 3.63. It has been connected to the boat wifi successfully for months with a static ip address from the boat router (192.168.50 range) and we can connect to it with the VRM app. We would also like to connect it to our Garmin 8616 MFD using ethernet to see Victron information on the Garmin screens.
The Garmin DHCP server assigns the Cerbo an IP address in the 172.16 range with subnet 255.255.0.0 and we lose VRM connectivity. I tried setting an IP address on the Cerbo ethernet to the boat network range and that worked for VRM but the Garmin could no longer find the device.
How can I configure the Cerbo and/or our router to use wifi for internet and ethernet for Garmin MFD’s concurrently?
Thank you for writing. Setting the Ethernet gateway to 0.0.0.0 on the Cerbo did not work. The screenshot mentions using the Ethernet to connect to a LAN while the connection I’m making is directly to an RJ45 port on the Garmin MFD.
Did you ever find a solution to your connectivity issue? I’m having the same problem. I can connect to wifi, or I can connect to Garmin. But when connected to both, only the garmin keeps communicating via ethernet.
Hi Jason, no I never got it to work and gave up. We are using the Victron Remote Management app over wifi only and not able to see the Victron info on the Garmins.
