Integration Cerbo GX MK2 dans MFD Garmin
I am trying to integrate a Cerbo GX MK 2 from 2024 (v3.53) into an MFD GARMIN 8412 from 2020 (software version 38.03). I bought 2 Garmin cables (010-10550-10) and a Network PoE Isolation Coupler (010-10580-10) but I can’t do anything! .
On the Cerbo GX MK2, I activated in: Settings/Services/MQTT Access and connected the Garmin RJ45 cable into VE.Can port 2 with a VE.Can & CAN-bus BMS profile (250 kbit/s)
Thank you for your help !
Did you ever get this resolved? I’m having similar issues.
If you want to connect through network you then also need to use the network port on the Cerbo. VE.Can is Can-Bus which is not the same thing.
You can also use Can-Bus but then you need to use NMEA2000 on the Garmin side.
Do you have multiple Garmin GPSMAP units or just one? If you have multiple units, you actually need to connect the Victron unit to the network box called GMS 10.
I have multiple units (2) and a GSM 10. That’s how I initially tried to connect with no luck. Troubleshooting attempt was to plug directly into the unit’s network port.
Yep, I’m using network ports
When using the networks ports of the Garmin and the Cerbo is the Network PoE Isolation Coupler required if there is no PoE device?
