I repeated this title from a legacy post; basically the goal is to switch the solar array from MPPT input over to the grid feed. I have a BMV712 smart.
Can anyone please suggest a suitable relay?
Many thanks
Many thanks
What do you mean by MPPT feed-in? ![]()
You want to switch the solar panels from the Mppt to another inverter … which should then feed into the grid.
A kind of switching of a balcony system from storage to feed-in?
The cables connecting the solar panels to the MPPT; I’d like to break into this ‘feed’ and through means of a relay, switch over to feeding a grid micro inverter.
Yes! Exactly
What PV power voltage/current are we talking about?
Two panels each at 440 W
(Vmp)|33,37V|
(Imp)|13,18A|
Tell us a bit more about your battery and your mains inverter … type etc.
The problem is first of all switching the direct current … a relay tends to stick when it switch under load.
4 x 12 V lead acid 200 Ah connected in parallel
MultiPlus 12/1600/70
MPPT 250/100
I’m not really sure of the purpose here.
Is it so you can charge the battery from solar then switch to grid feed in once full?
Yes exactly!
Two panels each at 440 W and a MPPT 250/100 ???
Is there more PV to come?
Do you still have a feed-in inverter or should that be the Multi?
I don’t quite understand the point either…
What Country we are talking about ?
Oh, dear maybe my thinking is wrong!
The PV is currently limited to these two panels.
Basically, as you’ve both alluded to, once the battery system is full, the array is not doing much hence it should be switched over to a micro-inverter that feeds the grid (house mains) directly.
There’s better ways to do this.
What country? Do your county regulations allow feed in via the multiplus?
Germany. Feeding back up the wire to the best of my knowledge is not permitted. A maximum of 800 W via micro-inverter (balcony set-up) is currently permitted.
… das hab ich mir fast gedacht ![]()
Unsere VDE …
Dann ist der Multi hier ja erstmal völlig ausserhalb der Betrachtung … der wäre ja nur für “Notstrom”
Lass den Microinverter doch einfach parallel an den Panelen dran und nimm ihm nur die Netzeinspeisung weg … und dem Mppt den Remote Eingang … das schaltet sich viel einfacher
so schaltest du keine Gleichspannung der PV
Danke das klingt interessant! Also, habe ich richtig verstanden, die Panelen mit jeweils mit ‘Y’ Verbindungen einrichten und einmal an der MPPT und einmal an der Micro-Inverter verbinden. Was oder wie steuert der MPPT Remote Anschluß der ‘Umschalten’?
da musst du mal mit der Relaisfunktion des BMV spielen. Hier musst du deinen AGM ja ein bisschen Zeit geben um nicht gleich bei Spannung “X” umzuschalten. Da kenne ich den BMV aber zu wenig.
Wichtig wäre ein elektronisches Relais welches mit 12V schaltet … also zb. ein Eltako ER12-200-UC mit 2 Schließern UND noch ein Relais ER12-110-UC welches dann deinen Remote schaltet.
Vielen Dank für Deine Hilfe und Unterstützung; ich wird nach diese Relais schauen!
… bekommst du nur 2 PV Module verbaut ?
