i have a small istallation and i need help with advices after i had a severe brain stroke , i want my phönix 48/5000 remote control via my lan network , i am no more able to concentrate very long time, but i can walk to the setup which is in another biuilding than my office, first :question is, is there a lan connection build in the inverter , if yes how can i connect to it via lan, i control 2 mppt with usb servers and the lithium batteries with cameras: only the leds in the manual for phönix i found this
2x RJ45 connector for remote controlcan i remotely switch the inverter on and off: thats what i want over my lan network what hardware is needed to do so ?
Not built into the inverter no. But a GX would have one. You would have to add it.
Seems overly complicated for no reason (unless you van share it). A GX would do this too. And so would decent base programming.
If you got a GX then node red and mqtt as well as other programming and integration options would open up for you.
i had a cerbo gx and was very disappointed, as it was not able to show my 3 mppt and i had no dhcp running and i am still on win7 has the phönix a ve direct connectori could use with a usb virtual link
Strange. Seems like it could have been resolved easier than what you are trying now.
Possibly you could use an mk3 to usb adaptor as well. Though i have never tried to control it without a venus system in place at least.
I am going to move your post to modifications as that seem the direction you are taking.
