Hi Does Victron have LAN monitoring to access Solar Charge Controller status?
They have Bluetooth and probably Cloud but I need local LAN Thank you.
I am considering a 150/100
Currently I have Epever 10414AN with LAN access.
Hi if you need local lan, you will need a cerbo or ekrano GX, then you can use an mppt with VE direct connection to access it
Or you can build one with a raspberry pi with venus OS
Many Thanks, Marc
