Firmware update on old Phoenix MultiPlus 24/3000/70 with firmware 1710134
Good day.
I have an old Phoenix MultiPlus 24/3000/70 with firmware 1710134.
I can connect to it via MK2, it reads grid and battery data, I can change some settings, less than on new processors, but all the main ones are there.
According to the firmware update instructions, it says that it should not connect via VE.BUS below version 18xxxxxx, but everything is ok with me, I connect and change the settings.
Is it possible to find a new firmware for it somewhere? And will it connect via VE.BUS to Cerbo GX after the update? With the current firmware, Cerbo does not see it. I put it on the second phase of the network, but it ends up working on its own, not in the general network of devices.
I saw a similar topic on the forum, but there the person couldn’t connect to the device. and there is no solution there.
There are no FW updates available for that old device.
sad, so it will power the backup systems. I often come across old inverters on boats, usually they die completely and I replace them with new ones. And here the client decided to increase the power, and gave me the old one. I was thinking about how to integrate it into my system.
Thanks for the answer.
