My ESS malfunctioned
Problem:
Reboot of the Cerbo every 10-15 minutes caused by Overload CPU
Solving: Deactivation of the RC.local file
Used ADDONS:
3x PV inverter
Worked before 3.70… like the 3.67 upcomming malfunction by 3.71-> 3.73 … with the update i cant still add the 3em nor the 3em pro as a (“GRID” )“PV inverter” or “Consumer” … please fix this this issue is killing me… something changed in the Python lib so fare i located the Problem…
21:00 i deleted every RC.local application and service from the Cerbo …
LOG (bevore)
The above exception was the direct cause of the following exception:
Traceback (most recent call last):
File “/usr/lib/python3.12/site-packages/requests/adapters.py”, line 667, in send
resp = conn.urlopen(
File “/usr/lib/python3.12/site-packages/urllib3/connectionpool.py”, line 843, in urlopen
retries = retries.increment(
File “/usr/lib/python3.12/site-packages/urllib3/util/retry.py”, line 474, in increment
raise reraise(type(error), error, _stacktrace)
File “/usr/lib/python3.12/site-packages/urllib3/util/util.py”, line 39, in reraise
raise value
File “/usr/lib/python3.12/site-packages/urllib3/connectionpool.py”, line 789, in urlopen
response = self._make_request(
File “/usr/lib/python3.12/site-packages/urllib3/connectionpool.py”, line 538, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File “/usr/lib/python3.12/site-packages/urllib3/connectionpool.py”, line 369, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host=‘192.168.176.232’, port=80): Read timed out. (read timeout=5)
During handling of the above exception, another exception occurred:
File “/data/dbus-shelly-3em-smartmeterKACO/dbus-shelly-3em-smartmeter.py”, line 160, in _update
meter_data = self._getShellyData()
File “/data/dbus-shelly-3em-smartmeterKACO/dbus-shelly-3em-smartmeter.py”, line 134, in _getShellyData
meter_r = requests.get(url = URL, timeout=5)
File “/usr/lib/python3.12/site-packages/requests/api.py”, line 73, in get
return request(“get”, url, params=params, **kwargs)
File “/usr/lib/python3.12/site-packages/requests/api.py”, line 59, in request
return session.request(method=method, url=url, **kwargs)
File “/usr/lib/python3.12/site-packages/requests/sessions.py”, line 589, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3.12/site-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3.12/site-packages/requests/adapters.py”, line 713, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host=‘192.168.176.232’, port=80): Read timed out. (read timeout=5)
2026-05-21 17:15:10,820 root CRITICAL Error getting data from Shelly - check network or Shelly status. Setting power values to 0. Details: HTTPConnectionPool(host=‘192.168.176.232’, port=80): Read timed out. (read timeout=5)
File “/usr/lib/python3.12/site-packages/urllib3/connectionpool.py”, line 536, in _make_request
response = conn.getresponse()
File “/usr/lib/python3.12/site-packages/urllib3/connection.py”, line 464, in getresponse
httplib_response = super().getresponse()
File “/usr/lib/python3.12/http/client.py”, line 1450, in getresponse
response.begin()
File “/usr/lib/python3.12/http/client.py”, line 336, in begin
version, status, reason = self._read_status()
File “/usr/lib/python3.12/http/client.py”, line 297, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), “iso-8859-1”)
File “/usr/lib/python3.12/socket.py”, line 720, in readinto
return self._sock.recv_into(b)
TimeoutError: timed out
raise value
2026-05-21 17:15:31,197 root CRITICAL Error getting data from Shelly - check network or Shelly status. Setting power values to 0. Details: HTTPConnectionPool(host=‘192.168.176.232’, port=80): Read timed out. (read timeout=5)
response.begin()
raise value
2026-05-21 17:17:05,77 root CRITICAL Error getting data from Shelly - check network or Shelly status. Setting power values to 0. Details: HTTPConnectionPool(host=‘192.168.176.232’, port=80): Read timed out. (read timeout=5)
response.begin()
raise value
2026-05-21 17:18:04,783 root CRITICAL Error getting data from Shelly - check network or Shelly status. Setting power values to 0. Details: HTTPConnectionPool(host=‘192.168.176.232’, port=80): Read timed out. (read timeout=5)
response.begin()
raise value
2026-05-21 18:28:18,260 root CRITICAL Error getting data from Shelly - check network or Shelly status. Setting power values to 0. Details: HTTPConnectionPool(host=‘192.168.176.232’, port=80): Read timed out. (read timeout=5)
response.begin()
raise value
