EVCS connect to cebro (venus) AP
Hello there,
I have seen network disconnection of EVCS from the home wifi network as a result of low WIFI signal quality due to the longer distance between the home WIFI AP and EVCS. Could I connect EVCS to Cebro WIFI AP as an alternative to the home WIFI AP? Note: Cebro is at a shorter distance to EVCS, so the WIFI signal is also much better at the EVCS side.
I haven’t tried it, as I wanted to double-check here first.. whether this would be a proper setup and whether these 2 devices will be able to see each other in VRM. Thank you.
