EVCS wifi Communication failure
I have a ev charger (EVCS-HQ2319) and sometimes i have the problem that it stops communication on the wifi.
Bluetooth is still working, but the ev charger also gives a failure that it can’t communicate to the cerbo also.
The only way to fix this is to power cycle the unit or a restart of the unit over bluetooth and then it works again.
Hi dumbo2
There is already a forum thread for this. In my case disabling a router feature called “roaming assistant” helped. I did end up installing an extra access point so the evcs has good connection.
Thanks for the info. Will read the post.
