EVCS changes position from AC IN to AC OUT
Hi everyone,
in one of my installations I have a strange issue with the EVCS indication in the VRM dashboard. Although the EVCS position is initally configured on AC IN periodically the position changes by itself to AC OUT and the EVCS is indicated in the wrong position in VRM. When I open the device in the device list, the position is also ‘wrong’ in the GENERAL / CHARGER tab and when I change it there back to AC IN after a few seconds it reverts to AC OUT.
Only when I perform a reboot of the EVCS everything reverts back to normal. This has already happened 3 times, so obviously no bad luck here?
EVCS FW version is 2.05 and Venus OS 3.67. Is this a kwown issue and is any permanent solution available?
Best regards, Jochen
