Good day team
I have an evcharger von Victron with display and after I did the update v2.03 display going on and off , all work fine with charging car just display make me worry , what should I do?
Best regards Gabriel
Good day team
Hi. Download the firmware and reflash it manually, then wait a few hours. Everything should return to normal.
Alex
Hello @Gabrielul . There may be some problems with display communication. Let me check your system. I will write you a PM.
I have same issue, display with no labels a informations
after firmware reinstallation all is working fine, firmware was downloaded from victron professional
Hello @DVR. It looks like the display is stuck. We’ve seen this may happen on some HW in cases where the contactor opens while current is still flowing through it. We can try adjusting the timing on your EVCS so it waits for the EV to stop drawing power before cutting off the contactor. I will send you PM.
