I have a battery storage installation for a solar powered light tower that incorporates a MPPT, Multiplus inverter, Smart Shunt, and an Ekrano GX. Recently I saw a message on the Ekrano GX screen that a firmware update was starting, and since then, the screen has been blank white and seems to be frozen after booting back up. The system remains to function in the background, and power cycling the system/ device does not fix the issue.
The firmware version updated from v3.34 to v3.67. The other 11 units still have v3.34 and the Ekrano functions as it should.
I tried installing v3.34 SWU file onto a USB and plugged it into a USB slot on the Ekrano, but this did not work when booting it up to force a re-install of the old firmware version. Not sure if I’ve missed a step or done this incorrectly?
Has anyone run into this before, and how did you fix it?
I/we were not the ones that originally configured the Ekrano GX for this system. Not knowing how difficult/ simple it is to configure, is there a way to copy that configuration over from one of the other 11 units we have?
OGPS
(Ed @ Off-Grid Power Systems - offgridps.com)
4
@guystewart Guy, Sean has a question about saving and applying VenusOS settings. Thank you.
guystewart
(Guy Stewart (Victron Community Manager))
5
