Hi, I have the latest Ekrano Display along with 600 amps lithium, VE BMS NG. Phone shows battery percentage SoC via Bluetooth but nothing on Ekrano display. I have followed instructions from a previous post (back in may) that I found but still nothing. Connected to VE bus and VE direct 1 ports on back of unit. Any ideas? Are there any issues with the latest Ekrano Display?
What other components do you have?
Unfortunately the VE.Bus BMS doesn’t transmit the SOC via VE.Bus.
(at least not jet, will maybe come with an update)
So you would need a BMV or SmartShunt for that.
Yes, as I wrote, you need a BMV or SmartShunt for the SOC.
You could also activate the battery monitor of the MultiPlus (VE.config) but that isn’t as accurate as a BMV/SmartShunt.
Matthias,
Thankyou for help.
Regards,
J
