Hello there, trying to connect in parallel identical GXii 48/5000, with identical VRM ID numbers, both units are connected to the same 48V/600Ah battery bank (identical lenght of DC wiring). Updated both units to latest F/W ver.3.70 over Remote Console. Physically disconnected GX card (power, short blue RJ45) in one of the units. However when connecting units together through VE.bus I’m getting fault message on both units stating Code #25. And this message on VRM Portal “ VE.Bus System [275] - VE.Bus Error: VE.Bus Error 25: Firmware incompatibility. The firmware of one of the connected device is not sufficiently up to date to operate in conjunction with this device “
Just to add, I do have MK3 dongle connected to Windows laptop.
I’ve tried to use VE.Bus Quick Configure, that failed too with message about incompatibility of units.
Any help would be appreciated
