Hi, I have recently installed an easy solar 2 gx 24/3000/70 with two 400ah iTechworld lithium batteries and am wondering how to ensure the charging profile is correct for the usage. I’ve tried going through the settings in the vrm app using the remote console but can’t seem to locate the settings. Any help would be greatly appreciated thanks!
The mppt can be programmed over Bluetooth with Victron connect, however the easy solar needs either the mk3 adapter and victron connect or you program it over the vrm (in browser not the vrm app) usung ve config and a windows laptop
You will also need a balancer. Did you get one already? Victron make one, they are not 2 bad but only take 1amp from the high battery. These are pretty good. The Heltec ones can move up to 10a from the high to the low. There are a few other ones out, Powmr powerqueen black boxes that move 5-7A from high to low. They all work. I tried them all. The Victron one might struggle with 400ah and a 70A charger.
