I have an EasySolar-II 3000VA with a bank of 48v pylontech LiFePo4 batteries and a solar array connected to it.
I want to be able to charge the batteries in parallel with some sort of dumb 48v charger that runs from AC, the aim is not to have more total charging current available but rather that the additional charger would simply “support” the battery voltage (for example, holding the batteries at 70% for longer during discharge, so the inverter in the EasySolar would be supplying AC output while the secondary DC charger would be supplying that power on the DC side)
If it helps to clarify what I’m looking to do, the idea is that during the day the system is charging it’s own batteries and is also charging an EV. At night, the system starts discharging, it’s own batteries discharge a bit (let’s say to 70%) then the EV’s AC output (V2L) picks up the load via a DC charger connected to the EVs AC output and it holds the batteries at a voltage corresponding to 70% SOC while the EasySolar keeps inverting and supplying AC to the loads. At some point the EV hits its own lowest discharge target and cuts off the secondary charger, so now the pylontechs start discharging below 70% and keep supplying the AC loads until the minimum SOC is reached.
What’s the best way to do this? I don’t think victron sell a 48v AC charger, and putting a multiplus in seems both wasteful (I don’t need/want the inverter) and also potentially not the right thing to do as if you were paralleling them then the AC input source of both would need to be the same, whereas I specifically don’t want that: the AC input to the EasySolar is grid power, while the secondary charger should get it’s AC input from the EV.
Presumably I just want an AC to DC 48v charger, and can connect it to the DC side of the system without the EasySolar knowing it’s there or having any form of communication with it, and the EasySolar will simply see the batteries as holding up for longer because it doesn’t know the DC power is actually coming from another source than the batteries.
How does this work in terms of current and voltage also? Presumably it’s conceivable for both chargers to be charging the batteries simultaneously (although that’s not an intended mode of operation), so I need to make sure DC cables are sized appropriately for the maximum charge current of both chargers simultaneously. Are there any other safety considerations like that I might not have thought of?
If victron do make an AC to 48v charger suitable for this what model am I looking for and if they don’t what other options are well made and worth looking at?
