Hello everyone,
I am having an issue where Dynamic ESS will not successfully enable on my Victron system. I am hoping someone with experience (or Victron staff) can advise.
System overview
Inverters:
3 × Victron Multi RS Solar (3-phase ESS system)
GX device:
Cerbo GX (recent Venus OS, Dynamic ESS available)
Battery:
NKON ESS ~ 32.15 kWh, CAN-bus BMS (Seplos)
Grid connection:
3-phase, external grid meter installed and working
PV:
DC-coupled via Multi RS Solar
Loads:
All loads connected to the AC output (critical loads)
UPS / backup power:
Enabled and tested — works correctly during grid outage
Battery data (live from Cerbo GX)
Voltage: ~52–57 V
Charge Current Limit (CCL): ~185 A (at higher SoC)
Discharge Current Limit (DCL): 280 A
Max discharge power: ~16 kW
Max charge power: controlled by BMS
Local ESS configuration
ESS mode: Optimized with BatteryLife
Minimum SoC: 25%
System operates perfectly stable without Dynamic ESS
Dynamic ESS configuration (VRM)
System
Energy export allowed: Yes
Max import power: 17 kW
Max export power: 17 kW
Operating mode: Green mode
Battery
Capacity: 32.15 kWh
Max charge power: 16.1 kW
Max discharge power: 16.1 kW
Battery cost: 0.01 €/kWh
Energy prices
Country: Netherlands
Supplier: Zonneplan
Pricing: Dynamic
Buy & sell formula:
(P + 0.01653 + 0.1088) × 1.21
Negative prices allowed
All settings are saved and validated in VRM.
Problem description
When I enable Dynamic ESS from the VRM dashboard:
The system shows “Loading…”
Sometimes I see “Turning on in …”
ESS modes become greyed out (external control appears active)
Dynamic ESS never fully activates
Even after 15+ minutes, the status does not change
No error messages are shown
Battery behavior becomes inconsistent (sometimes discharging, sometimes idle)
Dynamic ESS never reaches a stable “active” state.
What I have already tried
Rebooting the Cerbo GX
Waiting until local ESS (BatteryLife) is active again
Turning Dynamic ESS ON again
Waiting >15 minutes without touching the system
Verifying ESS and grid metering configuration
Testing backup power / UPS (works correctly)
Result: same behavior every time.
Questions
Is this a known issue with Dynamic ESS on Multi RS Solar, especially during first activation?
Are there additional requirements or checks specific to the RS Solar platform?
Is there a way to reset or clear the Dynamic ESS state (GX or VRM side)?
Is anyone successfully running Dynamic ESS on a 3-phase Multi RS Solar system, and if so:
Venus OS version?
ESS / DESS settings?
Any guidance would be greatly appreciated.
Thank you in advance.
