hello all,
First of all, I am not an expert on this, but I have been working with Victron hardware and software for about 2 years now. So I might be overseeing an very easy step ![]()
Yesterday I was at a friend’s location, And within an hour or so we had Dynamic ESS (DESS) configured and running. Yet I can’t get it to work (whe way I would expect) at my own place.
So I hope one of you spots my mistake ![]()
For refference, this is my setup:
I have had this setup for a while now. In the past I created a Node-RED flow to do the following:
Read the Grid-meter, combine the power usage of my house for the 3 phases an compensate that with the MultiRS Setpoint (for example, if my use uses 1000w, set the MultiRS Setpoit -1000)
Then re-calculate that every 1 seccond and update the value acordingly. This way I would keep my energy usage next to nothing from the grid. (I call this Grid-0)
Sumer mode
This worked fine in the sumer, more then enough Solar power to keep my house at Grid-0
Winter mode
There is not enough solar power available, so I try a different route;
Calculate the ‘cheapest’ hour of the day. Then try to top off the battery with the cheapest power.
Then calculate (or guess a little) when to ‘spend’ battery power, for example I used to wait for the 8-most-expensive hours (Mostly morning 06:00-09:00 & evening 17:00-22:00).
Then when prices are high I started my Node-RED flow again to keep Grid-0 again.
Although this was far from perfect, it worked most of the time.
So whith the latest firmware for the Multi RS it started supporting DESS. And I think DESS would do a better job than my Node-RED flows. But somehow I can’t ged it to work the way I would expect. (Or maybe, I just don’t understand it correct;))
So yesterday for example I would have kind of expetec this;
Charge the battery at arrounc 03:00 when it’s cheap, and atleast save me some money by pushing back to the grid when power is the most expensive, right?
What actually ended up happening was this, nothing.
The battery was not used to ‘push back’ against the Grid at all.
Only a bit of usage on the battery for my server rack (via AC-Out1) and a bit of Solar charge, but nothing being done by DESS…
So what do you guys think; Have I not understand the software? Or might I have a configuration error somewhere down the road.
For refference, my DESS Configuration:
Any help would be appreciated, thanks in adavnce!
