Does anyone know the default password for a Cerbo GX or VRM Online
I am getting a login with your password message when I try to access the Cerbo on VRM Online.
There isn’t a default password for that; you set up your username and password when you create a VRM account.
If you haven’t created a VRM account yet, please do so here: VRM Portal - Victron Energy
Editing to add: if you’re just trying to connect locally, then switch to “Local” in your VictronConnect and use one of the methods described in the manual: 7. Accessing the GX device
I guess he means the remote console.
@kgiesselman The remote console isn’t password protected by default.
The password is set by the user, maybe ask your installer.
I am my installer. I have not set a password. I have set-up a VRM account. That password doesn’t work.
I am not sure this is the solution.
Did you set up a password for access on the Cerbo via LAN. Settings > General > Access & Security > Local network security profile - is this set to secured. You may not get these menu items if you are on old firmware.
If you did and can not recall it then Section 8.4.2 in the manual (linked below) describes how you can reset all wifi / Bluetooth / network to Factory settings using the push button. This may clear.
If all else fails then a factory reset as described in the manual could be used to start again.
Yes, I did set up a password for the local security profile. That login works.
