Easy solar 2 gx lack of generator controls
Subject: Request for Firmware Update – Missing Generator Controls on EasySolar-II GX
Dear Victron Engineering Team,
I am writing to express my disappointment regarding the lack of accessible generator control functionality on my Victron EasySolar-II 48/5000/70-50 GX system.
Your product literature and online documentation strongly suggest that generator start/stop controls, silent period settings, and manual start/stop are available directly through the GX Console (Remote Console / Victron app). Unfortunately, this is not the case on the EasySolar-II GX model as shipped.
Issues encountered
  • The Generator Start/Stop menu does not appear anywhere in Remote Console unless the internal relay is manually re-assigned in a way not described in the manuals.
  • The front-panel display contains no menu access, despite documentation implying that configuration is possible.
  • The EasySolar-II GX presents itself as a fully GX-integrated unit, yet essential generator-related menus are hidden, inaccessible, or missing entirely.
  • Online resources and printed literature lead users to believe that generator control is straightforward on GX-equipped models, which is misleading in real-world usage.
Impact
For off-grid users like myself, generator automation is critical. Without accessible settings, the system cannot be configured to:
  • Automatically start/stop a generator based on voltage, SOC, load, or time-of-day
  • Enforce “quiet hours” (silent times)
  • Provide a manual start/stop button in the console
  • Expose relay configuration in a predictable, documented way
This makes generator integration far more difficult than advertised, and not at all consistent with what Victron’s documentation implies.
Request to Victron
I kindly request that the engineering team:
  1. Release a firmware update for Venus OS on the EasySolar-II GX that makes:
    • Generator Start/Stop menu visible by default
    • Manual start/stop control available in the console
    • Silent-period scheduling built-in
    • Relay assignment for generator control intuitive and properly documented
  2. Update the documentation to clearly distinguish between:
    • Cerbo GX / Venus GX behavior
    • Internal GX implementations on EasySolar-II units
    • Front-panel display limitations
This would prevent further confusion and greatly improve user experience for off-grid installations.
Relevant community references
To illustrate that this is not an isolated issue, here are two Victron Community threads showing the same problem:
These threads demonstrate that the issue is widespread and has persisted for several firmware generations.
Tags for engineering visibility
easysolar-ii-gx
I have found a solution to the lack of visible generator controls in VRM with the EasySolar 2. Some will likely already know aboit this. I installed a BMV 710 and that has a relay in it. In, device - setting, in the console, I was able to put in voltage values for starting and stopping the generator. I looked at progamming the K1 relay through adding an assistant, but I wanted to be able to manually control the generator, which is not possible with the K1 relay. I still feel Victron have been sahdy with this not clearly stating their is no way to visibly controll a generator with the EasySolar 2 because there is no relay on the GX. That means you can’t have a start stop control in VRM.
