Can I connect a display panel to the Victron EasySolar-II GX 24/3000? If so, what are the available options.
No. It does not have a HDMI interface.
If you connect to the GX’s hotspot you can then use the rconsole or if it is connected to a LAN/wifi via its IP address or venus.local.
Okay thanks! So I can’t connect the Victron GX Touch 50 with Cerbo GX to the EasySolar-II GX 24/3000/70-32 MPPT 250/70?
What I’ve done, just hang an old iPad mini on the wall and add a charging cable. Connect to the GX IP address and enjoy your screen with Venus OS.
Thank you!
Thanks!
