To the systems experts;
- Can you point me to a document covering this, or
- Can you answer any of the questions below?
What is the difference between a retail Cerbo-GX mk2, and the Cerbo-GX you would find in an EasySolar-II?
Things in common:
- both have 1 ethernet port
- both have wifi and bluetooth
- same CPU, memory, and onboard storage
- 2 VE.Can ports
Things i think i can confirm are different;
- blue plastic case on the retail version, vs a plain (potted?) board in the EasySolar-II
- VE.Direct (taking up one port) to the MPPT is already routed for you in an EasySolar-II
- 1 VE.Direct port on the EasySolar-II (i.e two in total, but one is for the internal MPPT) vs 3 for the retail version.
- 1 USB port only on the EasySolar-II vs 3 on the retail version?
- No SD card slot on the EasySolar-II
- Separate images, but maybe feature parity with Cerbo, and both can run “Large”
Things i’m looking to confirm
- no HDMI port on the EasySolar-II?
- Are they the same image? (and “large” can be turned on to get NodeRed going?)
Edit1: Only 1 VE.Bus on the EasySolar, and its internal, vs 2 on the retail verson
Edit2: Updated the SD card, thanks to @Ramatt
